John deere 224 square baler
crisok
08-24-2007 17:49:02
I need some help in timing this machine. I have made many attempt but I can't figure it out. Help
haymaster
08-25-2007 12:48:09
 Re: John deere 224 square baler in reply to crisok, 08-24-2007 17:49:02
Trip the measuring arm and roll the plungerhead toward the feeder fingers, pushing the flywheel conterclockwise. be sure that the feeder fingers clear the bale chamber just before the plungerhead gets there. Adjust the feeder finger drive chain if the plungerhead contacts them. after this is done keep rolling the plungerhead. when the needles start moving and the needle tips are just entering the bale case, stop and measure the distance from the needle tips to the face of the plungerhead, should be between 1" and 2 1/2". If this is not correct then disconnect the chain at the trip dog clutch and roll the plungerhead til it has this distance. then roll the trip hub until it hits the trip dog and reconnect the chain. Its a pain 'cause of the tight area in which you have to move the chain.Anyway this should complete the timing. finish rolling the plungerhead around until everything is reset and trip the measuring arm and cycle the system to see if it is right. You may have to readjust the safety stop if it was way out of time and make sure the needles are clear out of the bale chamber in the home position. Doesn't matter if its a wire or twine baler the timing is the same.
banjo
08-24-2007 20:21:11
What kind is it ? wire or twine
I have a manual for a 224 wire tie. what is it doing or not doing?
crisok
08-29-2007 18:04:50
 Re: John deere 224 square baler in reply to banjo, 08-24-2007 20:21:11
It is not clearing the needles. I have set the chain on the knotter assembly. What happened is that the plunger arm that connects to the bale assembly the bolt broke out and the arm came off and it bent the bottom i had it welded and it now hits the bottom of the baler body.
