Best Mower for Woven Fence Lines?
CB in central N
08-22-2007 07:36:39
I have a couple of miles of fence lines in my pastures I have to keep mowed. I can only get so close with the brushhog (within about 10 inches or so). I am looking for ideas regarding the best type of mower to get up close to the fence short of walking it with a weed trimmer (which I have done too).
I"ve seen ones that have their own engine (such as the one offered by Northern Tools) and can be dragged in the offset position along the fence. My problem is, my fences are all woven, so I have "stay" wires all the way to the ground. Any trimmer line will simply shred itself on the vertical wires, unlike regular high-tensile fence, where you can just drag it under the bottom horizontal wire.
Any ideas / suggestions will be appreciated. Thanks in advance.
Don-Wi
08-23-2007 01:35:44
 Re: Best Mower for Woven Fence Lines? in reply to CB in central NY, 08-22-2007 07:36:39
How bout goats? They keep a yard clipped real well. Their poo is plenty small enoguh too...
Donovan from Wisconsin
Chrisco
08-22-2007 17:05:26
third party image
I have used it and it worked great. Like Glennster said.
johns48jdb
08-22-2007 16:18:07
my local garden supply has a product called hindo. its 70 a gallon and you only use 4 tablespoonsfulls per gallon. goes a long ways and works good. i mis it a little stronger than that.
johns48jdb
08-22-2007 16:32:53
 Re: Best Mower for Woven Fence Lines? in reply to johns48jdb, 08-22-2007 16:18:07
just got out of first grade. should spell honcho.
glennster
08-22-2007 10:23:56
swisher makes an offset tow behind mower just for trimming around fences and such. its self powered, kind of a big weed eater. the mower end is spring loaded and has a guard that will follow around fence posts and such. i havent used one but the look pretty slick.
El Toro
08-22-2007 09:59:49
I would spray it too. Hal
Ebbsspeed
08-22-2007 10:20:10
 Re: Best Mower for Woven Fence Lines? in reply to El Toro, 08-22-2007 09:59:49
Yup, spray. If you clear a wide enough area it also keeps the critters from pushing on the fence trying to get the greener stuff on the other side. 'Course if the other side is a neighbors patch you might want to make sure it's OK with them.
Formerly PaMIke
08-22-2007 09:30:31
Spray it. We had a guy come in with a boom mower. Big mistake. Since the mower is way out to the side everytime the tractor moves up and down the mower moves much more. He took out the top of several posts, broke the barb wire etc. Mow up close and spray the rest.
Jerry/MT
08-22-2007 09:07:15
I've seen offset rotary mowers. If they stick out beyond your wheels then you can get closer to the fence. I think KingKutter makes one and I believe Worksaver or Land Pride dos also. Search their web pages.
RodInNS
08-22-2007 08:53:11
Honestly.... That sounds like a job for a couple quarts of glyphosphate...
Anything short of a string trimmer is going to be hell near a page wire fence, but then pagewire was meant for hell anyway...
Rod
BCnT
08-22-2007 07:58:13
i spray my field fence a couple times a year with roundup.
