Ford 150 Baler Needles
PVF1799
08-20-2007 07:39:16
I need needles for a Ford 150 Series 509 Serial# 1490. Does anyone know where to puchase either new or used?
Thanks in advance, Ken
Errin OH
08-21-2007 10:22:36
 Re: Ford 150 Baler Needles in reply to PVF1799, 08-20-2007 07:39:16
I have a few spares (used) off of a mod 250 series 504. I do not know if they are the same but if you can look for a casting number (side of the needle) I will compair it with what I have.
PVF1799
08-21-2007 10:37:33
 Re: Ford 150 Baler Needles in reply to Errin OH, 08-21-2007 10:22:36
I have sent my father out to get the number and will get it to you. Thanks for trying.
Ken
RodInNS
08-20-2007 10:44:54
I would also suggest trying NewHolland... I don't know if they have them or not, but it's worth a shot. Otherwise, get them to a good welder who knows how to weld cast. There isn't a reason in the world why they can't be glued back together...
Rod
RickB
08-20-2007 15:45:31
 Re: Ford 150 Baler Needles in reply to RodInNS, 08-20-2007 10:44:54
P/N 106864 needle; no longer serviced from New Holland.
georgeky
08-20-2007 10:57:46
Rod, you are right. I have seen many of them welded back together and worked for years.
georgeky
08-20-2007 09:40:21
Don't know about the 150, but needles for 530 and so on are available from New Holland. They cost as much as the baler is worth.
