oliver 2 bottom help
cowboy9
08-19-2007 17:21:49
Just got an oliver two bottom trail plow. The plow is said to be an adjustable width sod plow. It has one regular handle for depth control and one crank handle for the other side depth control. It also has really long and twisted moldboards with small shears. The number on the main beam is EP 8028. Any info on this plow would be very appreciated.
Thanks,
Dana
Leroy
08-20-2007 16:06:13
 Re: oliver 2 bottom help in reply to cowboy9, 08-19-2007 17:21:49
I can't help you on model number but Oliver did make several different adjustable frame plows for different furrow sizes. It sounds like your plow is a clutch lift and not a hydrolic cylinder lift. Do the shares look like a small triangle? If so then it has on what several manufactures called a scotch bottom and is a 10" bottom, I think all plow makers that used that type bottom bought them from the same place.
