TO-210 Offset Disc
DJD-Man
08-18-2007 17:31:45
Could somebody be of some help as to what horsepower is needed to pull a 210 14 foot tamdam offset disc. Would a 720, 730, 830 be enough power to pull it? Any other advise or suggestions is appreciated. Thanks.
Gannman
08-20-2007 15:52:41
 Re: TO-210 Offset Disc in reply to DJD-Man, 08-18-2007 17:31:45
I have heard that a good gauge for an offset disk is 10 HP per lineal foot wide. so a 14 foot offset would need a 140 hp tractor to pull it with ease. just my 2.
JMS/MN
08-20-2007 09:26:05
A JD 210 is a tandem disc- not an offset. They were available with standard concave disc blades and cone style blades. I've had the cone since 1977, and it's a good match for the 4020 diesel- 94 pto hp. When I used it with the 3020 diesel- 70 hp, it was underpowered. Would not pull it faster than 3rd gear, while the 4020 did a good job in 4th. Both were PS, with duals. Biggest personal dislike is the cast standard that connects the gang to the frame. Easier to break than steel. 210 is a medium weight/duty disc- ok on plowed ground, but not heavy enough for turning stalks, etc. Your 830 might not be too bad of a match for it.
Jimmy King
08-19-2007 19:18:21
I used to pull a 7 ft Roam with a 54 hp tractor and it was all it needed.
evilboweviel
08-19-2007 13:21:37
yup until you drop it in the ground then dualed up/ 4 wheel drive 150 hp to use it right
ron
RodInNS
08-18-2007 19:55:03
Not sure I follow.... There's tandem discs and offset discs, and a WORLD of difference between the two.
Tandem has 4 gangs. The offset has 2 and looks like half a tandem.
A 14' tandem will want 60+ hp to handle in light soil, and likely a lot more to really make much use of it...
An offset disc will want 150 horse in front to handle 14'. That's no toy...
Rod
DJD-Man
08-18-2007 21:20:17
 Re: TO-210 Offset Disc in reply to RodInNS, 08-18-2007 19:55:03
Sorry, that would be 14' offset. Still looking at 60 plus?
RodInNS
08-19-2007 13:45:18
 Re: TO-210 Offset Disc in reply to DJD-Man, 08-18-2007 21:20:17
It would be 150 PLUS in my soil which is light... At the very least you can figure on that, and then some.
Rod
