IH #8 Genius plow
seedsntrees
08-11-2007 08:06:20
Hwllo,
Does anyone have a lead for spare parts for this plow?
I need the rear tire & rim.
Thanks,
Maark
08-12-2007 16:26:37
 Re: IH #8 Genius plow in reply to seedsntrees, 08-11-2007 08:06:20
I have a rim without the tire. Email is open.
seedsntrees
08-12-2007 17:18:47
 Re: IH #8 Genius plow in reply to Maark, 08-12-2007 16:26:37
Hi, I sent you an email.
Thanks,
georgeky
08-11-2007 09:12:25
I found one, but it is pretty much shot. Rusted through in 3 or 4 places. If I run across another I will let you know.
georgeky
08-11-2007 10:54:17
If you don't have any luck with Miller let me know and I will look through my junk and see if I might have a good one.
seedsntrees
08-11-2007 14:00:27
 Re: IH #8 Genius plow in reply to georgeky, 08-11-2007 10:54:17
Hello,
I tried Miller Tire.
The person I talked to said that they might not have that rim any longer.
I might have to try some implement dealers / junk yards.
Do you have a rim?
Thanks,
georgeky
08-11-2007 15:12:05
 Re: IH #8 Genius plow in reply to seedsntrees, 08-11-2007 14:00:27
I don't know as I will have to look and see what I do have. They were also used on old semi mount IH mowers, such as the 31. I will let you know what I find.
seedsntrees
08-11-2007 16:29:29
 Re: IH #8 Genius plow in reply to georgeky, 08-11-2007 15:12:05
Thanks for looking. Maybe one will show up.
Last resort will be to cut mine up and weld the center section to a boat trailer rim.
Regards,
georgeky
08-11-2007 10:49:29
I think Miller does carry those rims, but not sure. I did find their number it is 1-800-621-1955.
georgeky
08-11-2007 08:36:49
What do you need? Some parts are available new depending on which bottoms you have. I get most of my parts by buying a parts plow.
seedsntrees
08-11-2007 08:51:23
 Re: IH #8 Genius plow in reply to georgeky, 08-11-2007 08:36:49
Looking for the rear furrow rim & tire.
Mine has a hole in the rim.
Thanks,
georgeky
08-11-2007 10:06:24
 Re: IH #8 Genius plow in reply to seedsntrees, 08-11-2007 08:51:23
You might check with Miller Tire. I think they have some of those rims. Is it the 3 bolt rim?
seedsntrees
08-11-2007 10:17:44
 Re: IH #8 Genius plow in reply to georgeky, 08-11-2007 10:06:24
Yes, you are correct. It is a 3-bolt pattern rim.
Gwiz
08-11-2007 15:09:04
 Re: IH #8 Genius plow in reply to seedsntrees, 08-11-2007 10:17:44
I just cut the center out of mine and welded on a new rim.
James
