Now, if you have a hay farm that far north, probably only 1 cutting a year? Maybe 2? And, you just want to spruce up the hay, but you will continue to hire the baling done????? _Then_ the little fella can get you done what you need - if slowly. You might wish to plow 20 acres a year, disk them, harrow/pack them, run a seeder over it, & pack it again. In 3 years you will have 60 acres of good alfalfa. A field lasts perhaps 5 years on average, maybe a tad longer. So, when you get done planting 20 acre plots, you will get a year or 3 off, then start in again. Remember that alfalfa is auto-toxic to it's own seedlings, so you need to plant something else for a year before returning an alfalfa field to new alfalfa..... Be a nice rotation for you, not everything in one year.... I remember the neighbor farming 80 acres of good rowcrops & oats & hay with an N tractor. So those saying it can be done are true - but it was his whole life, & his 3 kids worked at it a lot too. It was not a part time job. The N will not keep up with making the hay for you. It would pull the side rake & maybe wagons. So, still not sure of your final goal here. If you want to totally farm 60 acres, do it all yourself, you need more tractor. If you want to slowly upgrade your hay ground, it can do it - slowly - with a 1-2 bottom small plow, a 6-8 foot disk, a harrow/drag, a seeder (drill or broadcast) and preferably also a packer. Alfalfa likes nuteral ph, so you will need to add lime if your soil tests low. This is real important. It also like P & K - but you need your ph right first. It has little use for added N, because it makes it's own. A soil test is a good thing - you need it to find the ph, might as well find the P & K levels too, should only be $20 or less - your govt might offer free even. A sprayer sure is helpful for getting rid of perannual weeds before you seed the crop, and to help knock down some after planting. Also alfalfa tends to get aphids & other bugs around 'here', don't know if you want to spray insecticides or let the pros do that with their charcol filter cabs..... A sickle mower or rotory bush hog might be nice to knock down weeds or cut a bit of grass yourself, but certainly not as a prinmary alfalfa mowing machine. You're underpowered & no live pto for doing the major hay cutting. But, as I and others mentioned, the N can't handle cutting & baling the hay on that many acres. You'll need a tractor with a bit more power, live pto, and slower gear choices to be any fun at all running those implements. If you don't mind going slow at the improvements, and continue to hire out the mowing & baling, that N might just do it for you. --->Paul
