Solving Moco problem
Fern(Mi)
08-09-2007 18:46:01
We�ve a Hesston�s 1400 moco (& 1345 roco) so I�m talking the 1400.
Hay wrapping on Moco Roller. Have had the same problem when the cutter bad knives had dulled the crop then not clearly cut clean causing crop wraps from over loading slugs hitting the rollers. It�s like picking up a chunk of wind fallen tree branch the first round of a wood lot or tree line bordering. Also is your reel steadily feeding the auger or rollers evenly. Lastly, I don�t start mowing a heavy hay field until 2:00 PM on a dry day. Wet rain soaked, dew cover stands can stick and wrap grass around all the rollers. Also, with a heavy crop as you suggest you may have to slow down. I�ve often cut first cuttings in 1st, 2nd, and 3rd gear with the moco. Right now into 2nd cuttings I�m running 5th gear. Most important keep PTO RPM�s up for your tractor.
I don�t mow my lawn unless it�s dry for I don�t like getting down to clean my deck.
From the humid State of Michigan
Fernan
