IH 656 Deal or not?
Jayelgert
08-08-2007 10:50:28
Hi there all. I just bought an IH 656 gas for $3000. 3 pt Hitch. 540 PTO. Tin is straight, paint is good, rear rubber is 50% right side, 100% left side, and the other 50% rear came with the tractor. It was only changed because the tube was bad and the owner didn"t want to change just the tube. I was thinking maybe I should change the one side over to the original 50% tire and save the new one for when it"s time to change both. Tractor runs 100%, TA is good, 1 small drip from the seal between the trans and the TA from the vent hole. Seat is new & even the lights all work. Front end is tight & as new. My question is, I think I did ok, but I"ve been a green guy for a long time. I more or less bought it because I could use another tractor and it seemed like a pretty good deal to me. What do you all think?
Jay
railhead
08-08-2007 14:57:30
 Re: IH 656 Deal or not? in reply to Jayelgert, 08-08-2007 10:50:28
Youve been a green guy? That is too bad.
You got a good buy on a Great IH model (656). Maybe there is still hope for you after all. I hope you have good luck with it.
souNdguy
08-08-2007 12:05:58
I'd say you got a cherry of a deal.
That single drip of oil is a non issue. I've had new tractors that had a drip of oil on them... no biggie.
I think yuo are right on about the tire.. store it in a place outta the sun and runt he old ones till you get a flat. then buy 1 new and you will be good to go..
soundguy
redih55
08-08-2007 11:16:30
Sounds like you got a good deal to me. I generally see those tractors sell between 3500-7500, depending on condition
