72 inch rotary tiller
Robert Mull
08-07-2007 06:52:02
I am looking to buy a Three point hitch 72 inch Rotary Tiller. What brand is better or worse. Chain or gear drive? This is for use in Georgia clay and gray soil. I will plow it up first and use the tiller to bust up the clods in the garden.
johns48jdb
08-08-2007 13:55:33
 Re: 72 inch rotary tiller in reply to Robert Mull, 08-07-2007 06:52:02
get a bush hog name brand tiller. you'll never have a problem with it, if you keep it serviced.
Robert Mull
08-08-2007 08:00:04
Thanks to all for the information.
Jim Ohio
08-07-2007 20:11:00
I have a Land Pride RTR 1558,it has the tines that go the opposite direction of the tractor and really chew up the ground for a good seed bed. Not the cheapest, but the best bang for the buck IMHO, Jim
J Plunkett
08-07-2007 15:05:48
If you are going to buy a tiller,order it and get one with 6 tines per rotor don't let anybody talk you out of it. You can run twice as fast and do the same job or go slow and chew up sod twice as much.I have a Befco its on third set of tines nothing else.A lot of the time with the six tine you can go fast enough to stay ahead of the dust
mark
08-07-2007 14:37:56
Robert,
There are many who claim gear drive is the ONLY way to go.....but have you priced one like a Howard? Just like a Rolls Royce....the best is wonderful if you have deep pockets, but most of us don't.
I have a Befco chain drive driven unit and it must be 25 years old. I've re-tined it once and replaced the oil seals, but beyond that, never had a problem and I run it with my JD that is making 62 PTO horses. Ground speed is an issue, but most any tractor having hi/lo range is suitable.
Many folks get the idea that they can avoid owning/using a disk harrow and most of the time, that is a mistake. If you should happen to plow wet ground in the spring....clods can form big as footballs and hard as rocks. This is hard on a tiller. The disk will cleave the big clods down to a workable size and then the tiller can make a decent seed bed. If you will plow in the fall and let the freezes and thaws break the soil up, you can make a lettuce bed out of the whole garden using the tiller. Again, a tiller isn't always the best implement, especially if you have lots of clay ground. It will pulverize the soil so fine, that after a rain, it settles together and gets hard.
Robert Mull
08-07-2007 09:05:17
I will be using it on an AGCO Allis 5670 which has close to 70 PTO hp and has three speed ranges(Low, Med. and high) and a four forward speed which equals 12 forward speeds and a creeper gear.Also has 540 and 1000 rpm PTO and four wheel drive. So tractor speed is not a problem, but Rotary Tiller price will be. I would use it on a smaller tractor but as you said a slow gear is required.
Gerald J.
08-07-2007 08:46:52
BE sure to check the needed ground speed for such a tiller. Some demand not going over 1/2 mph and most tractors won't go that slow at standard PTO speed. Often the tiller drives the tractor and sometimes when the tiller gets too much dirt ingested it breaks the tiller or the PTO.
Gerald J.
