5500 heston
sam in mo
08-06-2007 16:19:52
Can someone tell me if I need to replace my elec. tie motor on my 5500 heston baler. It works good going one dir. but when you reverse it it is real slow or stalls and wont start. I am new to this big baler and am not sure if the motor is fixable or needs to be replaced. The wireing is good and nothing seems to be bent or misaligned. Thanks for any information. Sam
Smith1000
08-07-2007 19:02:18
 Re: 5500 heston in reply to sam in mo, 08-06-2007 16:19:52
Maybe the switch is bad. As much as the switch is used, it seems like could be bad going one direction. You could maybe test it by applying 12V directly to the wires. Just a thought. You can only hope it is the switch. If not, maybe the motor could be rebuilt somewhere if the new ones are really $500.
troy21
08-07-2007 10:49:50
well mabe it is binding somewere.. i know i priced one for mine and it was high.. im thainking it was like 4 or 500 bucks..
troy21
08-06-2007 18:56:59
do u got to much tension on the string.. that will make it hard for the tie to pull back in
sam in mo
08-07-2007 01:45:59
 Re: 5500 heston in reply to troy21, 08-06-2007 18:56:59
No string or hay in machine. Trying to make sure machine works properly before cuttin hay this fall. Thanks for the reply. Sam
