End Less Drive Belt
Arthur T. in SD
08-04-2007 06:09:42
Looking for information on how to repair a endless drive belt. Bad spot where grease from threshing machine dripped down on it.
:eroy
08-05-2007 17:26:31
 Re: End Less Drive Belt in reply to Arthur T. in SD, 08-04-2007 06:09:42
An endless belt does not have that splice in and that ruins a belt for small pulleys. Now if it is an endless belt chances are good it is a rubberised belt and if it is I would try the Blech White tire cleaner on it, I use that to rejuvinate wiper blades. Now if it is the canvas belt then I don't know but would probably try a dish washing soap like Dawn that is made for grease. just try not to completely soak the belt.
johns48jdb
08-05-2007 04:46:29
since its bad any way i wouldn"t be afraid to soak that bad spot in castrol super clean for a day or so. it will clean it pretty good. i guess i"m lost since i haven"t had much experience with those belts what difference does grease on it make. i can see it maybe slipping but is there any other reason why you can just give it a good cleaning. don"t use that castrol super clean from walmart in a purple jug indoors and don"t get down over it. it will take your breath away. other than that i"ve had good luck using it on cleaning even dried up oil based soaked paint brushes. it will bring them back to like new condition.
JOHN HARMON
08-04-2007 21:08:05
Find a good Farm Store and they can probably furnish you with the appropriate "Aligator" Fastner for your belt. I'm sure your Belt is spliced with one of them now if you would look some where on it. of
msb
08-04-2007 19:39:40
Cut it out and splice it.
