Will JD 350 9' sickle fit and operate on a Kubota L3400
dweitzel
08-03-2007 20:59:14
Will John Deere JD 350 9' sickle mower fit and operate on a Kubota L3400's 3-point lift arms and clear the top link assembly? I'm a little confused as some say yes it will, but others are saying that it will not fit between the lift arms? Can it be made to work on this tractor? Is the inside dimension on the rear wheels sufficient to run this mower? I have the AG tires on the tractor if that makes a difference. I think the turf tires may be a little wider if that helps.
I have one lined up to purchase but the owner does not know if it will fit and it's a bit of a drive to go test it out.
Any help would be appreciated.
Luke S
08-04-2007 06:07:55
 Re: Will JD 350 9' sickle fit and operate on a Kubota L3400 in reply to dweitzel, 08-03-2007 20:59:14
I wouldn't see why it wouldn't fit? take some measurements.
