Oliver Rake
peaster
08-03-2007 03:45:38
Does anybody know a source for rake teeth for an old Oliver ground driven side delivery rake. Not sure about model number. Its a 5 bar rake.
djm75
08-06-2007 04:04:40
 Re: Oliver Rake in reply to peaster, 08-03-2007 03:45:38
have you got a 207 or a 107?
Mark 770
08-05-2007 06:52:30
Theisen's has them. They are identical to New Idea teeth and that is what the bin at the store has them listed as. I've found that these are also not getting replenished near as often. I'm figuring at buying a good bunch while they are still around. The rubber ones work well for the newer 207 model but if it's the 107 and you want original then the New Idea listed ones are the way to go and match.
peaster
08-04-2007 06:57:04
Thanks guys I'll try tsc again. I looked the other day and was unimpressed with their stock of teeth. They said they thought they could order them but weren't sure. I'll like to get this old rake restored and usable.
djm75
08-04-2007 05:57:44
like Randy I use the rubber ones I get mine at theisens.
Randy as in Randy-IA
08-03-2007 19:47:22
Hi , Agco carries the spring type for the 107 and 207 and any farm store has the rubber universal type which works fine for the 207 . That's what I use on my 207 .
Lincoln
08-03-2007 11:52:06
Tractor Supply has them. Most times they don't have them on hand, but they can order them. I have an oliver 207 rake.
