where to get bale counter for 24T Baler
WhiteHavenFarm
08-01-2007 07:36:30
Hasnt worked for a while and id like to track down a new one. Im sure I can pull the part number out of the book when I get home but was wondering if anyone had one or knew the best place to get a good functioning or new one.
johns48jdb
08-01-2007 16:24:33
 Re: where to get bale counter for 24T Baler in reply to WhiteHavenFarm, 08-01-2007 07:36:30
if you like to tinker you can take them apart and sometimes you can make them work. i had a gear that was bad on the single digits so i took it and moved it over to the thousands side and could count up to 999 that way. i never put twine in mine without greasing it and could get about 500 bales out of a bundle. i would watch it pretty close and then put more twine in and reset it if i had to and make a note of the number of bales each time. i baled nearly 2500 bales one day and was able to keep up with it. that was back when i was young. i couldn"t do it now. we started bailing about 10 and was home for supper by 6 and all the hay was in the barn. we loaded it all by hand off the ground. i was running three one ton trucks and five guys to a truck though.
WhiteHavenFarm
08-03-2007 12:04:54
 Re: where to get bale counter for 24T Baler in reply to johns48jdb, 08-01-2007 16:24:33
I guess I can try that. I thing the single digit numbers are worn off but I didnt think of swapping it with a thousand digit. Ill be lucky if I get 50 bales of of my field these days. I sure as hell will never need the thousand digit
Lew Best
08-01-2007 09:18:54
I found one on ebay (new, resettable dial type counter) on ebay for 5 bux plus a reasonable amount of shipping (less than 5 bux shipping iirc?). search bale counter & if no results just try counter. All you need is a resettable (preferrably) counter with a trip lever.
Lew near Waco, TX
David from Kansas
08-01-2007 08:19:11
Not sure about a 24T, as they don"t show up in the JD parts site, but a counter (meter) for a 346, which I think is the same, is available from Deere at $84. The part number is DC15593. I have also seen them occasionally on ebay.
Maybe you could find one on an old junk baler. I think they were made by Veeder-Root. Usually the reason they fail, in my experience, is they get that ulta-fine dust in them because of the dirty place they sit on a baler.
Gary in TX
08-03-2007 05:11:39
 Re: where to get bale counter for 24T Baler in reply to David from Kansas, 08-01-2007 08:19:11
David,
I have not a clue where you get your information. I just pulled up a 346 Baler on Deeres parts online. Part number is AM3118E and the price is $23.93. I'm sure glad I don't buy parts at your parts store!
TomH in PA
08-01-2007 17:12:57
$84 ???!!
Yipes. I'm going to start buying junk balers just for the counters.
WhiteHavenFarm
08-01-2007 09:25:50
Sweet, thanx a bunch for the info guys. Ill poke around on the bay and see what I can find.
