international 444
Wal Arnot
07-31-2007 07:38:53
I have a inter 444. after sometime of using water, I have removed the head and found a blown head gasket. Can someone please post the head bolt tension setting, and tappet settings. Thanks, Wal
JV3CII
08-01-2007 13:55:46
 Re: international 444 in reply to Wal Arnot, 07-31-2007 07:38:53
Old trick for any of the IH BD-series engines...
Oil the head stud threads when you reassemble!
It'll give you about another 1/6 to 1/4 turn compared to reassembling dry (which ISTR the book tells you to do). It won't hurt anything but will help prevent further head gasket problems, which were always an issue with those engines.
Cheers, JV.
Larry in Mo
07-31-2007 11:42:09
Here you go Wal; head bolt torque is 80-90 ft. lbs. Valve tappet clearance is Int..014, Ex is .020 hot. When tightening head bolts start in the center and work in a clockwise pattern going toward each end while standing on the distributor side. LE
