 A no till planter needs a coulter out front, not for tillage (the "no till" wide ripple coulter only works in dry soil anyway, makes a disaster in wet dirt) but to cut the straw so the trash whippers can spread that cover away from the planting zone and then the planter opener has to open the trench, drop seed in it, and close the trench. I suspect the 494 is not a disk opener but a shoe and that is going to limit it to tilled ground. The picture is my 7000 planter after no tilling this spring. I also put down 32% N with the cutting coulters so they probably went a bit deeper than just needed for just cutting the straw. I was planting in bean straw. The chains on the back help cover the seed, so its said. They've been on this planter since it was bought new in 1974. Deere planters are in at least their 4th generation since the 494. No till gets easier after a few years when the soil finally stays mellow from frost action and no tillage, but initially its tough. An alternative might be strip till where a group of coulters stir up a strip 5 or 6" wide and then the planter is run in the same strip either immediately or weeks later. I tried a no till scheme with my old cyclo 400 planter one year. Without spraying it was very bad but the initial stand of the corn was good. I mounted clipped 6" cultivator shovels on their shanks on the front of the planter, one for each row. I didn't make the mounts strong enough so I lost some. They did have a tendency to act like a dump rake piling up stalks, but where they worked up a little seed bed the corn and beans came up nicely, just three weeks of rain preventing cutivating out the rest of the weeds that took over the fields. The corn wasn't worth combining and the beans did only 20 bushels but that year I expected a drought ahead of planting. That single cultivator shovel down 3 or 4" in front of each planter row may work, so long as you get with the spraying to kill off the weeds and cover crop. Gerald J.
