fast hitch 2 bottom plow
Deamer1
07-28-2007 21:37:44
HI,
I purchased a IH model 200 tractor. With it I have a 2 bottom plow which I cannot identify. I need help. The plow has the fast hitch prongs (two) and everything else to the rear of the prong on this plow looks like a "Little Genius plow: Anyone have any ideas what the model of this plow may be. This tractor is a 1956 model IH 200, the plow was purchased at the same time. The rear wheel of the plow is solid metal, no rubber. Any help is much appreciated.
Deamer1
Deamer1
07-29-2007 20:33:56
 Re: fast hitch 2 bottom plow in reply to Deamer1, 07-28-2007 21:37:44
Thanks for the input. I had no idea what it was. Are parts still available for the C20 plow? Any help is greatly appreciated.
georgeky
07-29-2007 21:28:02
 Re: fast hitch 2 bottom plow in reply to Deamer1, 07-29-2007 20:33:56
Some parts are available. Do you know which bottoms are on it? If it has Plow Chiefs the points are seperate from the share. If it has these the parts are a little pricey, but they last for years and do a great job of plowing. You also need to make sure your tractor has all the lift parts to operate the plow. There should be a long flat but angled bar on the right side that hooks to the lift arm under the gas tank. It controls the angle of the hitch and of the plow. It will not work without it. It also has a depth control rod on the right side of tractor that also hooks to the other lift arm. If you like send me an email and I will send some pics of a plow on the tractor with all this hooked up correctly. For parts call Brad Marshall at 1-888-824-0544 and he will send them right to you.
georgeky
07-29-2007 21:50:31
 Re: fast hitch 2 bottom plow in reply to georgeky, 07-29-2007 21:28:02
The long flat angled bar is on the left side instead of the right like I said in the other post.
Larry in GA
07-29-2007 06:31:43
Dreamer It is a C-20 a very nice plowing plow. Sets up easy. I have the manual for it if you want to e-mail me with any other questions Larry
georgeky
07-28-2007 21:41:10
It is a C-20 plow. It was sold for the Super C/200 and 230
