NH 310 baler and twine
Dave from MN
07-27-2007 19:22:14
Will plastic twine work in this baler. Sisal twine keeps busting, it was a few years old. It is not breaking at the know, ussually after it is tied, in the kicker, but mostly when the bales lands in or hits the side of the rack. Any suggestions.
Gene-WI
07-29-2007 06:57:53
 Re: NH 310 baler and twine in reply to Dave from MN, 07-27-2007 19:22:14
Should be able to run plastic if you have a pan style thrower, guess the belt ones burn the plastic twine. If your sisal twine is two years old I would suspect that it got damp and that is the reason it is breaking, try some new balls of twine. Generally 7200 is for thrower balers and 9000 is for chute balers but depending on the mfg both can work.
NHBalerman
07-28-2007 19:25:52
Try loosening the bolt on the twine tension at the twine disc,sounds like it has too much tension and is tearing the twine during knot formation and then when it gets some strain on it the twine will break. When the knot is being formed it needs to pull the strings from the twine disc just a little and if they are too tight this will happen,try loosening the bolt about 1 flat at a time,hope this helps.
dorset farmer
08-10-2007 09:36:26
 Re: NH 310 baler and twine in reply to NHBalerman, 07-28-2007 19:25:52
I may have the same problem, but don't understand your recommendation to loosen the bolt "one flat". Please explain. Thanks
backwoodsfarm
07-28-2007 13:00:37
I run a 273 with a model 54A bale thrower. I use 9000 sisal and never break a bale. I have 18 foot wagons. Is there any chance the twine is rubbing against a burr or sharp edge somewhere along its path? I also only use new holland brand twine.
troy21
07-28-2007 11:47:32
most of the newer bailers will run plactic without any adjustments.
