pto shaft removal
Walter Gorman
07-26-2007 11:07:46
I recently purchased a old bush hog and I am having problems getting the shaft off of the end closest to the bush hog.
The only identification # I see is m-(four numbers)
Did older bush hogs have set screws or allen type screws?
I need to shorten the length of the shaft. Thanks
Dave Anderson
07-26-2007 17:37:10
 Re: pto shaft removal in reply to Walter Gorman, 07-26-2007 11:07:46
Why fight the rust, just cut what you need to off with a hack saw! Use as coarse a blade as you can-rule of thumb is to have 3 teeth on the thinnest area of the cut.
Walter Gorman
07-26-2007 17:39:33
 Re: pto shaft removal in reply to Dave Anderson, 07-26-2007 17:37:10
Thanks very much. Have a great day Dave
