Heston 5580 baler
Jerry Kitt
07-22-2007 21:51:07
I blew a bearing on one of the rollers which is inside the bale chamber. I believe it is one of the bale forming rollers. It had a "clamp" at either end (7/16" wrench to remove it). Any simple ways to replace the bearing without having to remove the belts and the entire roller assembly?
The hay is dry and the forecast lousy.
troy21
07-23-2007 11:07:55
 Re: Heston 5580 baler in reply to Jerry Kitt, 07-22-2007 21:51:07
if its the roller that is on the cradle of the baler.. inside on the tision arm. the only way to replace that is to split the belts then open the gate and pull the hole cradle nout to get that roller out.. it has a allen headed bolt on each end of that roller and its so tight agenst the wall u have to pull it out and lay the cradle on the ground.. it aint to hard.. just time.. i had to do mine that way.. and i replaced all the berings n that cradle.. if u need any other help i can help u by looking at the book or telling how i did mine
