Name this part!
Robert Wilcox
07-22-2007 09:20:58
I am building a mini bush hog, using a 90deg gear box from a Hines H1600 mower deck.
This gear box has a rubber disc inline to cushion the PTO drivetrain.
Any ideas on the name of this rubber disc, and where I might find a replacement? It is about 5in in diameter, about 3/4in thick, with 4 bolt holes at the "compass points", each hole about 2in from center.
Thanks!
BasketCASE
07-23-2007 13:36:24
 Re: Name this part! in reply to Robert Wilcox, 07-22-2007 09:20:58
Some people call them a flex disc or a flex coupler
cj3b_jeep
07-23-2007 05:43:49
Go to an automotive junkyard, look at Ford trucks, they have something very simillar in the steering. I think they are caled a "steering damper".
Duane(Pa)
07-22-2007 20:02:33
My buddy had one on a Cub Cadet with the Kubota 3cyl. diesel engine. Rag joint
Jason Simmerman
07-22-2007 16:08:50
In the automotive world it is known as a rag joint...
johns48jdb
07-22-2007 14:50:50
if you decide to make it yourself see if you can get a piece of belting from a rock quarry. its tough stuff.
pork
07-22-2007 13:54:42
we had a Bushhog with the same thing. i didnt want to buy any so i took and old conveyor belt and hole punch to make my own. still going ater five years.
Robert Wilcox
07-22-2007 14:18:27
 Re: Name this part! in reply to pork, 07-22-2007 13:54:42
Thinking about getting some rubber automotive exhaust hangers and piecing something together.
I have one "old school" tractor shop I will check with before I engage in Adaptive Engineering!
Jerry/MT
07-22-2007 13:15:02
A damper?
El Toro
07-22-2007 13:08:06
Try this place on Monday. Hal
www.machinecomp.com/
Sid
07-22-2007 12:57:58
Try looking for slip clutches and toque limiters.
Sid
07-22-2007 12:57:37
Farmall Mann
07-22-2007 10:19:52
google hines manufacturing rocky mount n.c. 27803 good luck I.B.
Robert Wilcox
07-22-2007 10:51:23
 Re: Name this part! in reply to Farmall Mann, 07-22-2007 10:19:52
I am hoping to find this part in the aftermarket. I've seen them before on various machines, even smaller versions as cushions in auto and truck steering columns.
Just cant seem to find a name for it, makes websearching for the part tough!
Bob
07-22-2007 18:00:19
 Re: Name this part! in reply to Robert Wilcox, 07-22-2007 10:51:23
A Morse "Morflex" coupling will replace the ragjoint. It consists of 2 steel halves riveted together, with rubber do-nuts to cushion the load.
