I don't have any info on mounting to a Farmall H or M. Ours is a JD H. Looking at the #5 Ops Manual, pg 69, it looks like the H drawbar and supports are hi-lited to indicate they are special or modified. Perhaps it is just the support rods which go from axle housing down on an angle. I'm not familiar enough with the H to really know. BUT, if it were me, I would block up the mower to specified height, back tractor up, and figure out how to make it work. If it is really that much too high (19-20") you could fabricate some heavy brackets or straps which bolt onto the top of the mower flat bar and then bolt onto top of tractor drawbar. If necessary, make the portion bolting onto the mower twice as thick, with the extra thickness below the bracket and on top of the mower flatbar. This will drop the mower by a measurement equal to the combined thicknesses of the tractor drawbar, the bracket, and the extra spacer. Make the brackets so each has two bolts going into the mower flatbar. (Or should also work with 2 going into the tractor drawbar). I used this idea to mount the flatbar to my 8N 3PH cross drawbar, only had one hole at each end of the bracket, and had real problems keeping the mower in position and sufficient lead on the cutterbar. Regarding wheel position, I never have adjusted the tractor wheels to fit the mower. Probably couldn't even if I wanted because the JD H and A are both seized onto the splines. You just need to mount the mower so that the inner shoe on the cutterbar is outside of the RH rear wheel. Otherwise the tractor wheel will flatten hay that the mower won't be able to cut. Just my thoughts!! Sorry I couldn't be of more help
