NH 850 hydraulic cylinder
Ron-Mo
07-19-2007 12:22:20
I have an NH 850 baler that has a leaking hydraulic cylinder. It was just weeping a little last year, however when I drug it out this year it started a pretty good stream. I have the cylinder off, and o-rings, and a wiper seal for it, however so far I have been unable to get it apart. Do I just pull the set screw out of the side, and pull the wiper seal? Then the retaining ring? Thanks in advance for help.
mur ga
07-19-2007 14:43:35
 Re: NH 850 hydraulic cylinder in reply to Ron-Mo, 07-19-2007 12:22:20
I think that is the style that you remove the set screw completely and take a flat punch and gently tap the gland "that holds the wiper" down in the cyl to expose a snap ring. Remove the snap ring and pull the shaft,piston and gland out of the cyl.
Ron-MO
07-19-2007 18:05:37
 Re: NH 850 hydraulic cylinder in reply to mur ga, 07-19-2007 14:43:35
Thanks mur. That helped me out. Pretty obvious once you push the gland down in the sleeve. I was looking for a different type ring setup. Got it all reassembled and ready to put back on the baler now.
old
07-19-2007 18:58:32
 Re: NH 850 hydraulic cylinder in reply to Ron-MO, 07-19-2007 18:05:37
Last year I had the same problems with both of the ones on my 850. REBUILD both of them at the same time or you will end up with trouble. I found out the hard way. Send me an e-mail and I'll scan a brake down of the cylinder. Theres a snap ring you have to remove to get it apart and its not an easy one to get out BTDT. Now if your close enough to me I can show you and or help you rebuild what you have since I have BTDT twice last summer
