New Holland 499
pd143
07-18-2007 14:45:41
What are the things to look closely at when buying a used 499 hydroswing haybine.
KEH
07-18-2007 16:51:32
 Re: New Holland 499 in reply to pd143, 07-18-2007 14:45:41
Don't know a thing about that mower, but after bitter experience I suggest hooking the thing to a tractor and listen to it run, try out swing and whatever else you think needs checking out.
KEH
I love farmalls
07-20-2007 07:09:05
 Re: New Holland 499 in reply to KEH, 07-18-2007 16:51:32
Just make sure that you check the hanger bearing that is tucked up behind the rolls that drives the right hand wobble box. Be sure the sickle is timed correctly,the two halves are to come together and then pull apart, not suppose to travel in the same direction.
