Help w/ 658NH baler
Brent in TEXAS
07-17-2007 17:28:03
I have a 658nh baler and there is a bearing out on the middle sledge roller. How do you move the frame that the rollers mount in(it pivots at the bottom and moves forward as the bale gets bigger)The frame is stuck or under tension and I can not move it.
Gimpleg Fagon
07-17-2007 19:12:39
 Re: Help w/ 658NH baler in reply to Brent in TEXAS, 07-17-2007 17:28:03
The pivot roll has to come out. It's a lot easier if you take off the belts first. Take off the clutch on the left side of the baler. Lift the roll up on the gear side then lift it up and out.The sledge fram gets a lot of trash and rust between it and side of the baler. Getting the sledge fram out is sometimes a two man job. I use a cherry picker.
