IHC Plow bottoms
Leroy
07-17-2007 06:12:45
I recently got these plow bottoms and not sure of what they are called or the size (Were Not on any frame to measure that way). They are the IHC with seperate nose and edge and with a seperate shin. The bottoms each are slightly different in the numbering. One has IHC solid abouve the number as near as I can tell of 515 698 R5 and the other has 515 688 rs with just the word solid below the numbers. The moldboard has I think these numbers SC H1520492R1 and the frog with these numbers ?152R2. If I would be able to get the angle grinder with wire wheel on the numbers bight show up better or slightly different. Measuring at a 90* angle from the landside to the right back corner of the moldboard they measure ant to the share would be more but with the share worn I did not try to take that measurement. Would these be 12" bottoms or 14" bottoms or did IHC use the same moldboard for both 12" & 14" as JD did. Trying to figure out if they should go on a 12" frame or a 14" frame as I got both with these bottoms. Also how do I take the point off?
georgeky
07-17-2007 08:09:46
 Re: IHC Plow bottoms in reply to Leroy, 07-17-2007 06:12:45
I don't have any wat to check the numbers, but they sound like Plow Cheif bottoms. There is a bolt and point holder that has to be removed from the points to get them off. If no one else has any better info to post for you I will go look at mine later and get back to you. I have 12,14 and 16 inch Plow Cheif plows.
