bale spear/fork
mgm
07-17-2007 03:53:31
I just purchased a skid steer for the first time and need to move some large squares. Should i purchase a fork or spear for the skid steer is the ? Thanks in advance
Tx Jim
07-18-2007 03:36:34
 Re: bale spear/fork in reply to georgeky, 07-17-2007 03:53:31
MGM two spears are much better than one spear for large square bales. One tends to slip up through the hay. I wouldn't want to use forks. Tx Jim
Cliff Neubauer
07-17-2007 18:21:50
 Re: bale spear/fork in reply to mgm, 07-17-2007 03:53:31
With the pallet forks I think you would have to be careful not to get them into the dirt or the twine on the bales. Also with the forks there is nothing holding the bales to the forks so under the right conditions the bale could roll backwards and onto the skid steer.
Jerry/MT
07-17-2007 13:37:35
I believe ther are dual spear attachments for large square bales but I'm not sure about using them with a skid steer.
Billy NY
07-17-2007 05:44:34
Not that I am any expert on handling large squares and or round bales, but after recently spending a 12 hour day in the field, gathering up what I am told now was over 200 large squares and 100 small rounds with a late model Massey Ferguson with a FEL and regular pallet forks, I can honestly say that regular pallet forks can work, but when the quick tach double bale spear arrived, and I started using it, there certainly was no doubt in my mind that using pallet forks for these large bales is like eating potato chips with a fork LOL !
You may very well need a set of forks for other tasks, but after stuffing all those large squares onto a truck, 14 per load, and seeing the difference it makes in the time it takes to load, the choice is obvious. Mind you, before that day, I had never handled a large bale, and no I'm not any self annointed expert after one long day, but I have always learned very quickly when around tractors and heavy equipment. The farmer whom I helped had just started getting into the larger bales, and was kind of struggling using the forks to load as I watched, was tougher to back out when stacking sometimes and if you are not careful in the field you'll get a thick slice of dirt under the bale if you do not level your forks to the ground, which on this tractor was hard to see, that and potentially breaking twine if not careful. The person who baled these fields, brought the spear to me in the field, but having only one set, he still used the pallet forks on the skidsteer back at the barns, to stack.
Few photos:
third party image
2 smalls at a time, pick up one on the fly, then set closely to another, re-pick and carry. The large sqaures were still heavier than 2 of these, had to use lots of care on the hills with those
I did sometimes use the spears as a fork, by getting under a round on the flat, as I could not shove in 2 on top, the big bolts for the steel door on the truck were hanging things up, and with the reach of this tractor, I could not lift high enough to get enough tilt to back out and not lose the bale, was a learning experience, but still a very productive day
third party image
third party image
picked off center, to counter balance things a little
third party image
