24T baler
george pickerin
07-14-2007 18:53:03
what would make the knotter gears not go back to there home position i have filed the gears and got the right tolerances and they still do it thank for any input
george pickering
07-17-2007 02:35:19
 Re: 24T baler in reply to george pickering, 07-14-2007 18:53:03
i did foreget too mention it is only doing it on the left knotter the right knotter works great
Mn Dave
07-16-2007 05:36:16
Not much help with your baler, but dad bought a new 24T in '64 and it still works as good as new. We only took it into the JD dealer once for a "check over" one winter. Doesn't miss a bale, maybe sometimes when it changes to a new ball of twine.
third party image
Tx Jim
07-16-2007 04:00:09
 Re: 24T baler in reply to Lew Best, 07-14-2007 18:53:03
George I forgot to mention that Bernie had a very possible cause in that the needle brake not holding. Tx Jim
Tx Jim
07-16-2007 03:56:11
 Re: 24T baler in reply to nyny, 07-14-2007 18:53:03
George the knotters and needles are driven by same mechanism which is a spring operated dog on shaft. Check dog mechanism for wear. Tx Jim
TimS in Mo
07-15-2007 20:22:43
How much slop is there in the chains? If they are worn, lots of bad and hard to diagnose things happen, hard to keep timed, etc....
`Bernie in MA
07-15-2007 18:05:24
It could be possible the needle brake is too loose. Do the needles not come home too?
george pickering
07-17-2007 02:33:10
 Re: 24T baler in reply to `Bernie in MA, 07-15-2007 18:05:24
nope the needles do what they suppose too
gary tomaszewski
07-15-2007 10:31:00
Only a guess, but are all the roll pins that hold the gears in good shape. Possibly one is sheared inside and catching enough to drive but not completing the cycle.
