488 haybine
mgm
07-12-2007 13:43:23
i own a 488 NH haybine and the rubber on the roller is tearing off. I heard it is very expensive to replace and difficult. Is there a problem with using the haybine without rubber any other ideas?
John e.c.MI
07-12-2007 19:34:12
 Re: 488 haybine in reply to mgm, 07-12-2007 13:43:23
Along time ago we had that problem. You can 'buy' a little time by drilling and tapping a hole into the roller where the rubber is peeling off and putting a bolt with a large fender washer to hold it in place. It won't last forever but it might get through the season. Eventually we wound up replacing the roll.
paul
07-12-2007 19:09:44
Without the rubber, you get no crimping action, so the hay won't dry as fast. With bits missing, bits of hay will be wet, bits will be dry, so it is hard to bale at the 'right' time.
A little bit of shipping won't make much difference on the price of those rollers. :)
--->Paul
Jason Simmerman
07-12-2007 16:30:36
Wow, you wore the rubber right off the rolls??? We had a old New Holland haybine 461 I think, and the rollers never went bad on it. We ended up junking it because the gearbox split after using it 30+ years, but never had a problem. Do you guys keeps yours outside uncovered maybe???
Eric SEI
07-13-2007 19:40:19
 Re: 488 haybine in reply to Jason Simmerman, 07-12-2007 16:30:36
We've got a Haybine and the rubber is coming off one of the rollers. I believe it is from the summer we had a category 4 or 5 tornado go through. We walked the fields pulling all sorts of debris out, but we still ended up with studs trying to go through the Haybine.
onefarmer
07-13-2007 19:03:53
Hi Jason,
The only time mine was kept outside was during hay season while in near daily use. Otherwise all our hay equipment is kept inside. I guess I just wore it out. Does seem like I've seen more 489's with replaced rolls than any other. Not that I've paid attention to it much
onefarmer
07-12-2007 15:06:24
I've been using a 489 that the rubber's been peeling for three years. Had to quite using it this summer because the hay began wrapping on the rolls. No kidding on the rolls being expansive. Priced them last year was $800 for one $900 for the other plus shipping from NH. There is a place that recovers them. Priced them this year and they want $2500 plus shipping. But I like the pattern they use better. I'll find them if you like. Have the link in my other computer.
RickB
07-12-2007 16:41:29
 Parts freight cost in reply to onefarmer, 07-12-2007 15:06:24
If you order rolls from a New Holland dealer and have them ordered on a stock order, you shouldn't pay shipping. If your dealer doesn't offer free freight to the dealership on stock ordered parts, find another dealer.
Ken Macfarlane
07-13-2007 05:18:49
 Re: Parts freight cost in reply to RickB, 07-12-2007 16:41:29
Our NH 489 lost the top rubber two years ago, was useless in long hay, would wrap in seconds. Almost 1300$ after labour to get it replaced. Always inside stored.
Some brands don't have the loss of rubber problem, case/ih mowers I've looked at have the stacked rubber with fabric for the crimper. They last until they rot out I suppose.
