Who's got a JD 530 Baler?
IaGary
07-11-2007 10:18:19
Do you like it?
Do they have auto tie or what?
One for sale close here that could replace my brothers that burned up.
Gary
cannonball
07-12-2007 05:32:42
 Re: Who's got a JD 530 Baler? in reply to IaGary, 07-11-2007 10:18:19
Gary a 530 is a good baler, unless it has been upgraded it has single tie arms and a pto shaft that will not allow you to turn very sharp..the 535 has both upgrades... the 530 has hyd tension on it and two large springs for bale tension...the hyd tension is charged off tractor when you close gate, then the valve takes over and you can adjust it to make the bales as tight as you want.. it has auto tie on it and has to have all springs on it to work right..has its on hyd tie system using a power steering pump... they made a good tight bale when i used them.. hope this helps
MAY GOD BLESS THE USA
Winky
07-11-2007 18:33:50
JD 530 were really a great baler, course new and improved are more advance. Vermeer is also a good baler. Makes a tight nice looking bale. The chain balers make a bale like a haystack, sloppy, and rough, although to each their very own little bully brain.
centralilbaler
07-11-2007 16:20:54
I love my 530.
JM In Merit
07-11-2007 12:38:44
Gary, what happened on his 605K? got a 605K myself and just curious what caused baler to catch on fire.
Serveral people around here run 530 balers, they seem to like them pretty well
Thanks
Jm
IaGary
07-11-2007 15:21:37
 Re: Who's got a JD 530 Baler? in reply to JM In Merit, 07-11-2007 12:38:44
third party image
The hay in the shed caught the baler on fire.
georgeky
07-11-2007 10:28:34
Gary, I have one. It has hydraulic tie on it. It has been a good baler and does a pretty good job.
IaGary
07-11-2007 10:21:04
Should have mentioned that he had a 605K Vemeer before.
