1034 stackliner routing of rolling rack cable
Jimmy in Ky
07-10-2007 10:04:55
In my 1034 operators manual it shows the placement of the cable but the drawing is not what i have... did N H have another way the cable is routed ?? maybe it was an (enginering change) that was not put in the book ... someone tried to run the cable but it was not right bent rack cyl. is what they did ... also it shows a tention spring in the book at the end of the cable at a 90`degree to the rack mine dont have the mounting for this.
Jimmy in Ky
07-10-2007 23:00:21
 Re: 1034 stackliner routing of rolling rack cable in reply to Jimmy in Ky, 07-10-2007 10:04:55
thanks for the info i will check the cable length and see it thats right
kyhayman
07-10-2007 18:10:13
There are two cables shown in the book. A return cable which is larger and a smaller cable which has the spring on it. I never used the smaller cable, getting the rack to go back isnt a problem. The larger cable is the one to be careful with too, if its the least bit too short it will bend the rod on the rolling rack cylinder.
Gwiz
07-10-2007 18:56:11
 Re: 1034 stackliner routing of rolling rack cable in reply to kyhayman, 07-10-2007 18:10:13
I just gotta ask if you learned that the same way I did(the hard way), or did someone warn you in advance?
James
kyhayman
07-10-2007 18:58:42
 Re: 1034 stackliner routing of rolling rack cable in reply to Gwiz, 07-10-2007 18:56:11
The same way :-(
Twice, in the same day. Cause Im slow....
I put the repaired cylinder, with the $385 new rod in it in and I still had the cable too short..... .....
Gwiz
07-11-2007 19:38:29
 Re: 1034 stackliner routing of rolling rack cable in reply to kyhayman, 07-10-2007 18:58:42
I'm sitting here chuckling even though that $400 and wasted time is not funny. I guess I was lucky; my wagon is the old 1030, I just bent the rolling rack a couple times. Nothing some time with a torch and cable puller couldn't fix.
James
Debb
08-19-2007 12:34:09
 Re: 1034 stackliner routing of rolling rack cable in reply to Gwiz, 07-11-2007 19:38:29
Hi , I see you have or had a 1030 NH stackliner? Am I correct? can I ask you some questions about it if you do own one?
