14T baler timing ?
oldnnew
07-08-2007 19:09:00
Hi all,
I attempted to time my JD 14T baler today. Here's the story.
I picked up an operators manual which has easy to follow instructions for timing the baler. I installed a new main drive chain, feeder chain and knotter chain. All chains have the correct amount of links according to the parts manual. After going through the timing sequence, the feeder arm is about 1/2" too far out. The high end spec in the book is 17 1/4" and mine is about 17 3/4". Does anyone know if this will make a heck of a lot of difference? The distance between the plunger and the needle tip is about 1 1/2 to 1 3/4" so I think i'm ok there. Anyone have any advice for me? I would really hate to grenade this baler again! Any help is appreciated! Thanks.
Tx Jim
07-09-2007 04:01:49
 Re: 14T baler timing ? in reply to georgeky, 07-08-2007 19:09:00
One only needs to re-time if a chain has been removed or has excessive slack to jump teeth. To time knotters/needles,trip tying system,turn flywheel CCW(forward) till plunger head points are even with needles when needles are flush with turned up channels in bottom of balecase. Tx Jim
Tx Jim
07-09-2007 03:32:09
 Re: 14T baler timing ? in reply to paul, 07-08-2007 19:09:00
I think you'll be fine on feeder forks even though I didn't remember the distance being that long but I have no 14T manual. On needles you should be good to go as I never measured them with a tape measure,I just set needles even with points on face of plungerhead. Tx Jim
garyburrus
07-09-2007 03:43:55
 Re: 14T baler timing ? in reply to Tx Jim, 07-09-2007 03:32:09
I am curious to know how to set the timing. I had to replace a knotter, and I'm just curious as to hwo to go about making sure that it is not out of tune.
Thanks!
