Horse Drawn Binder/Farmall H - How Fast?
Crazy Red Power
07-08-2007 14:41:42
I'm as green as my oats on this subject. I have a ground drive 7ft. Mc-D binder that I plan on using for oats in a month or so. The oats were broadcast in spring & I have a few spots of overlap where they came up pretty thick. I'm using an H to pull the binder & I am concerned the binder is going to bind up in the dense stuff. What gear do I use in regular crop density & do I speed up or slow down when I get into the heavy spots? Also, do I need the extra person on the seat? Or, can I just set the levers & everything before I get started? I only have about 4 acres to bind & everything came up pretty even.
Tx Jim
07-09-2007 03:46:11
 Re: Horse Drawn Binder/Farmall H - How Fast? in reply to Wapiti, 07-08-2007 14:41:42
Crazey Red around 2MPH as Leroy stated would be best. The difference about ground drive vs pto drive is changing MPH on ground drive also slows down/speeds up sickle,canvases and tying but doesn't really change it according to crop amount like changing pto rpm's does. In my youth I pulled a binder with a JD B many miles. Tx Jim
Leroy
07-08-2007 16:14:53
 Re: Horse Drawn Binder/Farmall H - How Fast? in reply to Crazy Red Power - SE-WI, 07-08-2007 14:41:42
Horse speed about 2 MPH, tractor low about 2 1/2MPH, use as high a gear as you can with the throttle pulled back, engine slowed down to get to that 2 MPH and still have enough engine power to do the pulling and keep the same speed at all times. If it seems to be overloading then take only a part of a cut, on seat depending if you want several bundles droped in same place or spread out when it is bundled.
