old or new small sprayer ?
Randy as in Ran
07-08-2007 13:32:48
Hi , I need to spray six acres of hay for thistle and other weeds this fall or later this summer anyway . For six acres should I just get a Fimco brand sprayer of about a twenty or thirty gallon capacity to pull behind the lawn tractor from the farm and fleet store with a 12 volt pump or double the outlay of cash and get a Hardi sprayer of the same size and type from the tractor dealer . Or should I wait for an auction and try to find a tph sprayer with a 100 or so gallon capacity ? I've been told the best time to spray for thistle is in September so I have till August to get one . Any suggestions , I'd like to have a good spot sprayer on it to . Thanks ...Randy
James22
07-09-2007 17:13:31
 Re: old or new small sprayer ? in reply to Randy as in Randy-IA, 07-08-2007 13:32:48
Small tractor sprayers either 3pt or pull type did sell cheap at auctions. I bought a 150 gallon ploy tank JD model 25A for $75. A few months later an auctioneer handling a sale for a retired farmer didn't bother to get a 25A out of the shed, said "nobody wants one". Also saw a trailing model JD 32A (300 gallon?) go for peanuts. Problem might be now that most have been discarded. Ask local auctioneers if small sprayers are regularly available. If scarce and you don't intend to spray very often, go to F&F and spend the minimum necessary to get the job done.
Don-Wi
07-09-2007 08:17:48
My brother and I just bought a 30 gallon Fimco sprayer this season to spray our pumpkins with a pre-emergence herbicide. Worked good too, and the rate we sprayed it was the full 30 gallon tank over 1 acre behind our L&G tractor.
It only has 2 spray nozzles right now, but we're looking at modifying it to have 3 or 4, but I'm afraid we'll need a bigger pump (brother doesn't always think of these things....)
Donovan from Wisconsin
RickL
07-09-2007 04:12:39
I have a 300 gal 3pt unit setup as spot sprayer,hyd pump.
Leroy
07-09-2007 01:56:03
If you want a good cheap 100 gal fiberglass tank JD sprayer take a trip to see family and stop by
IaGary
07-08-2007 19:32:18
You may kill the thistles better in Sept. but they will have already went to seed and will be back stronger next year with many more plants.
I try to get mine before they go to seed which is early June for musk thistle, June-July for Canada thistle and July- August for bull thistle.
Gary
Butcher
07-08-2007 15:15:39
Hi Randy. I might have what you are looking for. I am just north of Waterloo. Dont remember were your from in the state. I'll find out this week if we can sell it and send some pics if your interested. Its a pull type with a 100 gal tank.
email is open I think.
07-08-2007 15:59:43
 Re: old or new small sprayer ? in reply to Butcher, 07-08-2007 15:15:39
Hi Butcher , I sent you an email . Then I re- read your post . Disregard some of the questions about type . You should get my email so send pict's or just let me know where you live if you find you can sell it . I don't think you are very far from me , Ionia or Dunkerton area ? Thanks ! ...Randy
