identify this plow share/anyone need a set?
arthur ward
07-08-2007 09:43:40
third party image
got a set of these and don't know what they are for. any ideas? anyone interested in them?
here is one and the number off it:
21H3927 CY142ASOLID MM
john osterhaus
07-10-2007 15:40:18
 Re: identify this plow share/anyone need a set? in reply to arthur ward, 07-08-2007 09:43:40
If any one out there happens to have a share that was made by Silver Streak in Dyersville ,IA I am looking for some. It doesn't matter what if fits just that it was made by Silver Streak. My Grandfather was one of the owners of the company. Thanks.
Joe Leising
07-09-2007 06:55:48
I am interested in these. How much?
Joe
tractor_guy at yahoo dot com
arthur ward
07-09-2007 21:26:34
 Re: identify this plow share/anyone need a set? in reply to Joe Leising, 07-09-2007 06:55:48
joe, i emailed you but no response from you.
Leroy
07-09-2007 02:18:39
I can tell you what it is not and that it is not that Ferguson share the other poster thought it is. I have the plow he is talking about and they are made entirely different. With the red color it may be IHC, MH or Cockshutt but it is a quick attach share and for either a 14" or 16" plow. I can also tell that it is a used share as there are curves where if a new share would be straight lines with sharp angles
murn ga
07-08-2007 13:49:08
That sure looks like a 150.00 old Fergerson 12" share. After seeing your post on the n forum I would cut the L shape off and weld to my old share. I gurantee it will shed.
arthur ward
07-08-2007 14:19:06
 Re: identify this plow share/anyone need a set? in reply to murn ga, 07-08-2007 13:49:08
hi
the share measures 16" across the flat of the top. what does 150.00 mean? i have been googling forever and cannot find anything on these darn numbers.
murn ga
07-08-2007 16:09:15
 Re: identify this plow share/anyone need a set? in reply to arthur ward, 07-08-2007 14:19:06
That means as in Am dollars. Your share should have a duck bill like this one.The later throw away shares are 12 to 15 dollars each.
arthur ward
07-08-2007 16:55:11
 Re: identify this plow share/anyone need a set? in reply to murn ga, 07-08-2007 16:09:15
if i could find some shares for my dearborn 10-156 economy plow i would be happy. i have a bent one and needs replacing. neither of the two dearborns have a duck bill on them.
got a pic of what they should look like?
Leroy
07-09-2007 02:30:39
 Re: identify this plow share/anyone need a set? in reply to arthur ward, 07-08-2007 16:55:11
The Dearborn Economey plow used Oliver bottoms with just a cheap blade type throw away share that any good farm suply should be able to get. You just will need one of the old shares to match it up and you will need to know the width of cut for the plow, measure from No. 1 beam to No. 2 beam and use the same spot on each beam and that will give you the size. Measuring along the angle of the share like you are doing in the picture will not give you the size plow the share is used on. to get the size share in your picture take a large carpenters square and lay one edge against the flat edge on the left side of the share and read the measurement on the other leg of the square at the far back tip of the share and then have to add a bit as the correct measuring point is wore down.
arthur ward
07-08-2007 09:44:28
third party image
other side
