NH 650 net wrap problems
MarkinMo
07-07-2007 18:42:58
I have a problem with my NH 650 that I'm hoping someone can shed some light on. I'm having problems getting the baler to work with white net wrap. I've had the baler for about 3 years and have been using the black New Holland net wrap called fastnet. It works great. However, my dealer/supplier is out of stock and won't be getting any more in. I've tried two different kinds of the white with no success. The problem occurs when the bale is full and the duckbill inserts - the bale won't start or pickup the wrap. I've also had some problems with the stuff not cutting even if it does try to wrap. The knives are nearly new. Has anyone had any success with the white net wrap in a 650? There is a different spring position for the wrap brake tensioning, I've tried both settings. Of course I have several acres of hay down which I'm trying to get baled. Any help/suggestions would be appreciated.
