prob's plowing with my 50 John Deere
Jeff Palm
07-07-2007 09:55:51
I'm hoping somebody out there can help me figure why I keep bending my top link with a Deerborne 1 bottom / 3 point plow on my 50 JD.
I know the plow doesn't seem to center just right and the plow keeps swaying off to the right and bends the top link near the pin.
Is my Deerborne set up for a different tractor ... or can my JD 50 pull it with my 3 pt. add on?
Any help would sure be appreciated!
Jason SImmerman
07-10-2007 18:35:48
 Re: prob's plowing with my 50 John Deere in reply to Jeff Palm, 07-07-2007 09:55:51
Jeff, where abouts are you located? I know of somebody that might be interested in doing some horse trading.
Jeff Palm
07-10-2007 19:55:19
 Re: prob's plowing with my 50 John Deere in reply to Jason SImmerman, 07-10-2007 18:35:48
Jason ... sounds good. My plow is currently by Staples, MN ... but I could get it to St. Cloud (about 75 miles north of the twin cities).
What kind of "horse trading" are you thinking of?
HAPPY DEERE
07-07-2007 15:40:36
the problem is your only use a one bottom hook up 5x16s to it and hit it in about forth gear
Jeff Palm
07-07-2007 15:42:13
 Re: prob's plowing with my 50 John Deere in reply to HAPPY DEERE, 07-07-2007 15:40:36
Hey thanks ... you guys are great.
Dave Sherburne NY
07-07-2007 14:31:38
You got a problem but the 50 with a three pt should work If the plow is adjusted properly. 530s came with a 3pt and some 520s You have to have the rear wheel width adjusted right rear furrow wheel should be about 26" from the inside of the wheel to the center line of the tractor Then with the left wheel of the tractor up on a 8" block,the plow should set level front to back and side to side. Put the front of the tractor up on a block too. Try searching the archives for PLOW That plow is probrobly worth $200 maybe it would be better to sell it and by a trailer plow
2 bottom 14". Any ?? Email me.
Jeff Palm
07-07-2007 15:47:53
 Re: prob's plowing with my 50 John Deere in reply to Dave Sherburne NY, 07-07-2007 14:31:38
Thanks for taking the time to offer a few words of wisdom. I'm going to give your info. a try on Monday and see if can get a few things figured out. The links were also a great help.
Lanse
07-07-2007 13:05:30
Also, the Deere was never designed for a 3pt hitch, but for a trailer plow
Lanse
07-07-2007 13:02:38
Your deerborn was designed for an 8N
55 50
07-07-2007 12:47:10
What is the make of the 3 PT add-on? Seems like you may be missing some stabilizing chains.
Jeff Palm
07-07-2007 15:40:27
 Re: prob's plowing with my 50 John Deere in reply to 55 50, 07-07-2007 12:47:10
Hi thanks for the info. ... my 3 pt. came from>Link
Is there a certain number links the left side should have compared to the right? longer or shorter, etc?
Thanks
CENTAUR
07-07-2007 10:21:45
I think the DEARBORN is a solid plow with no shear protection as the FERGUSON system has a built in shock spring.This is only what I think at this time. CENTAUR
