New Holland 467 haybine roll problem
Ernie W
07-07-2007 05:32:53
I have a 467 haybine that has a cocked top roll. Looking from the back, the left hand side is about 2" higher than the left (and so is the spacing between the rolls).
Any ideas on how to fix it?
Ernie W
07-07-2007 05:36:29
 Re: New Holland 467 haybine roll problem in reply to Ernie W, 07-07-2007 05:32:53
Sorry, I meant the left hand side was 2 inches higher than the right.
Gene-WI
07-07-2007 13:15:25
 Re: New Holland 467 haybine roll problem in reply to Ernie W, 07-07-2007 05:36:29
Either a bearing is out on the side that is lower or on the arm that holds the roller there should be an adjustment stop that keeps the rollers from banging together and the rubber pad is missing.
