HP requirements
Devin Sparks
07-06-2007 05:51:29
I am looking at a JD 210 disc harrow that is 14 ft wide. What HP requirements would be needed to pull this disc. Would be for leveling only as I have a cutting offset disc.
Thanks
Randy as in Randy-IA
07-06-2007 20:35:47
 Re: HP requirements in reply to Devin Sparks, 07-06-2007 05:51:29
Hi , I am not ( by far ) a expert on the subject of disc harrows ( or anything else for that matter ;) ) . That said , I pulled a 21 foot Oliver 263 with 18" blades up and down a damp hill side ( 90 acres ) cutting cornstalks this spring with my 1755D oliver ( 86 HP - fresh rebuild , Loaded tires - singles - and cast centers with spin-outs and 50% tread ) I pulled it with the wheels up mostly at 5 - 6 mph unless I was getting stuck in the wet spot . The ground was fairly light and sandy in spots to heavier in other spots . The property owner got his planter tractor stuck in the same spot I got stuck in so it wasn't a tractor size problem I don't think . Moral of my experience - Your conditions might let you pull it with a tractor that has less HP than the majority thinks is needed to handle it . My neighbors didn't think my tractor would do it with the wings down but it did . I didn't feel as though I was tearing up my tractor , it only lugged down in a couple of spots otherwise it was a good workout for it . ...Randy
dboll
07-06-2007 14:15:44
I would want atleast 85 to 90 to pull it at 6mph, a 210 isn't a bad disk, buy a 215 and 130hp wouldn't be too much! the 110 isn't much more than a packer!
JMS/MN
07-06-2007 14:15:31
Depends on the disc blades. Cone blades were an option on the 210. They take more hp because they move more soil. I bought mine in 1977- it is a good match for the 4020- 94 pto hp. The 3020, under 70 pto hp, could not handle it and do a decent job. Both tractors had fluid rears and duals. Neighbors typically pulled an 18 foot disc with their 4020. You won't enjoy breaking and buying those cast iron standards. Way better choices in discs. Get something with solid steel supports for the disc gangs.
cj in wisconsin
07-06-2007 13:03:27
I use a 14 foot behind a 720 jd 58 hp. In heavy soil thats about she'll handle without duals and going real slow. 70 or more HP sounds like an accurate choice
georgeky
07-06-2007 12:40:33
A 35 or 40 HP tractor will not pull that disc. It will need at least 70 or more.
RodInNS
07-06-2007 07:49:50
I assume you mean that this is a tandem disc? Most times a light tandem disc can be handled with 70 hp or better, depending on the soil type. The heavier the soil, the more power that's needed. An offset of that size will probably want 130 + hp to work properly.
Rod
Lanse
07-06-2007 09:42:59
 Re: HP requirements in reply to RodInNS, 07-06-2007 07:49:50
I would go with a 40 or so HP, about 35-50, just make sure it has a good frame size, small tractors dont do well. These people are crazy.
RodInNS
07-06-2007 13:23:44
 Re: HP requirements in reply to Lanse, 07-06-2007 09:42:59
Have you ever actually pulled a tandem disc? Judging by your statements here, I'd say not, or you're a lot crazier than me.
Rod
Devin Sparks
07-06-2007 13:32:31
 Re: HP requirements in reply to RodInNS, 07-06-2007 13:23:44
Yes I have pulled a tandem disk. My other disc is a 10-12 Foot JD BWA which is a lot older than what I am looking. I have a 100 HP tractor and was just trying to get a feel for what would be needed. I turn to the people here because someone here will know the answer to all questions.
Thank you others for your reply.
Don-Wi
07-06-2007 14:39:13
 Re: HP requirements in reply to Devin Sparks, 07-06-2007 13:32:31
He was replying to the other guy- not you.
Without knowing what that disk looks like, I'd say you 100 HP tractor should be more than enough for a 14' tandem disk.
Donovan from Wisconsin
RodInNS
07-06-2007 16:17:45
 Re: HP requirements in reply to Don-Wi, 07-06-2007 14:39:13
Yes, the reply was to the other guy. Agree with you that the 100 horse will do fine.
Rod
Devin Sparks
07-06-2007 17:46:55
 Re: HP requirements in reply to RodInNS, 07-06-2007 16:17:45
Thank you again for your replys and to RodINNS sorry for the short string that I had. I agree with what you said and a 35-50 HP tractor would not pull this disc. BTDT with a MF 165 and JD BWA just to try to level the field. Works if you drop the wheels down but puts alot of stress on the old girl.
