Which way to the guard bolts go on a JD #5 mower?
unioncreek
07-05-2007 06:00:57
I was looking at a JD #5 mower that was sitting in a fence row the other day. The guard bolts had the nuts on the bottom side of the bar, when I got mine it had the nuts on top of the bar. Which way is right or is there a right way? With the nuts on the bottom it looks like the cut hay may flow over the bar easier.
Bobg
Lanse
07-06-2007 09:47:42
 Re: Which way to the guard bolts go on a JD #5 mower? in reply to unioncreek, 07-05-2007 06:00:57
This should help
http://retiredtractors.com/No5/index.htm
2t2@ia
07-05-2007 21:22:24
Seems to me that the original guards on our number 5 had the bolts in one way (I don"t remember which) and when we switched to rock guards, it was necessary to change the direction of the bolts. The only trouble we ever really had with it concerned the bolts that held the chain box to the frame. I finally used loctite and no more trouble.
Bob
07-05-2007 07:51:18
 According to the owner's manual.... in reply to unioncreek, 07-05-2007 06:00:57
The nuts are shown on the BOTTOM. (#5 Mower Operator's Manual OM-H10-250.)
The operator's manual for the (later) model #8 showns the nuts on TOP.
Allan In NE
07-05-2007 06:11:15
Nuts go up.
When that material crosses the bar, it is still standing up and the nuts don't matter one iotia.
Allan
Gerald J.
07-05-2007 06:10:04
With the bolt heads on the bottom the ground will flow by smoother. Its a lot stronger impediment to motion than the cut hay.
Gerald J.
