Grinder-mixer 101
Grub
07-03-2007 22:25:12
I have never operated a grinder-mixer and have a couple questions. I assume the grinder is a flail type beater so do you start that running and need a second tractor to drop in the hay/ corn/supplement as it is beating? Or do you load up all your feed and then start the grinder?
These are the things I wonder as I drive by the hog farm.
Thanks. Have a safe and happy 4th and fly those flags.
Grub
paul
07-04-2007 11:18:35
 Re: Grinder-mixer 101 in reply to Grub, 07-03-2007 22:25:12
For hogs, a batch grinder you start up, and put in the minerals, salt, & grain with a shovel or auger. No 2nd tractor is needed. It's actually fed in pretty slowly, 4-5" auger will keep up with most average size grinders. You can feed in small square bales by hand, _very_ slowly if you need hay in the mix - rarely done.
For some cattle rations a big tub grinder is used. Older style for round bales has a hammer mill on a bottom edge, start it up, use second tractor to drop in a bale, let it grind.
Newer style is a vertical mixer, again start it up, auger in the silage, grain, minerals, then drop in a round bale with a second tractor. They have 1 or 2 vertical augers that chew & chop the bales & silage up as they spin - slower than a flail hammer mill.
So, don't need a second tractor for anything without hay in it. Shovels or augers do the trick.
-->Paul
Allan In NE
07-04-2007 04:43:47
Start 'em up and start filling the salt, mineral, supplement and grain.
When she's full, the ration is mixed.
Allan
