New Holland 68 needle timing
davin003
07-02-2007 20:46:40
I tried to bale a log and thats when the fun began All the shear bolts broke Does anybody know how to set the needle timing. Thank you,Tom
Kelly C
07-03-2007 07:16:02
 Re: New Holland 68 needle timing in reply to davin003, 07-02-2007 20:46:40
third party image
Click on the link. I have instructions on my web site. Find the link on the left pane that says NH 68 also check out the baler FAQ.
Our Farmer
07-03-2007 05:12:08
There's an easier way.
Open the plunger pushrod cover an you'll see two marks to set the arm between to put it in a vertical position.
Then go back and open the door to the tine bar. On the deck you'll see two notches. When the arm is set in the upright position, the link which connects the time bar to the drive chain must be between those marks. That'll time your tine bar.
Lincoln
07-03-2007 09:40:45
 Re: New Holland 68 needle timing in reply to Our Farmer, 07-03-2007 05:12:08
That will time the feeder, not the needles.
Our Farmer
07-04-2007 04:36:25
 Re: New Holland 68 needle timing in reply to Lincoln, 07-03-2007 09:40:45
He said he broke all the shear bolts. He oughta check the timing on both.
Short Bolt
07-03-2007 04:11:45
If it times like a 67 NH hay liner. I might be able to help. Needles when in time, with plunger . just begin to enter bale chamber when the tips on plunger pass the needle points by 1/4-3/4 inch. rotate the fly wheel till the plunger crank is vertical between the marks on side frame. Remove knotter drive chain..Make sure the knotter clutch pawl is tight aginst the knotter stop. (Pull upward on needle yoke to make this happen). You will have 2 marks on the knotter drive clutch housing they should be in line. Put the knotter drive chain back and tighten idler make sure marks don't move rotate by hand through cycle. watch for needle entry time. If I can help please e-mail,, Thanks
