I'll suggest that there's three correct answers to this question, depending on how much wood you're going to split.... If you're doing a very small amount; not even enough to heat your own house, then running it off the tractor's hydraulics will likely do OK. It will be painfully slow because the old tractor doesn't move much oil, and the tractor will burn a lot of gast to do it.... but it's cheap to setup, and will do on a limited basis.If you're doing a fair amount of wood for yourself, or even on a very small commercial basis, then a small engine powered splitter with a 2 stage pump is probably the best way to go. It will use less gas in the long run and gives decent performance with the 2 stage pump.... IF you're into this in a serious way, moving commercial quantities, then don't waste your time on either. You want at minimum a 4" ram and a 20+ gpm pump, PTO driven, with it's own resevoir and controls. That's going to be a bunch more money, but it will buy you capacity. Right now I'm using a small trailed splitter that I built, and it's powered off the tractors hydraulics, or my skid steer.... but these rigs are all pumping 14-18 gpm, so they're relatively fast without running the engine fast, so the fuel use isn't too bad. I'm in the process of obtaining the parts to build a large commercial splitter though, and that will be PTO powered..... Rod
