AC Sickle broke
Trailbuster
07-01-2007 21:57:40
I just put my model 80 Sickle mower together because one of the gears in the Twinwheel box was broke when I bought it. But my knives don't move all the way into the ledger plates. I have one of the flywheels under the gearbox set opposite of the second one, so when one is swinging outward toward the cutter bar the other is swinging inward towards the frame. I thought this was the case in order to balance out the swinging flywheels. Is this wrong? Can someone look at theirs and let me know if this is right or not?
This is my first sickle mower can I can use some help.
Thanks,
Rob
Traditional Farmer
07-02-2007 02:39:13
 Re: AC Sickle broke in reply to Trailbuster, 07-01-2007 21:57:40
They should mirror each other both out at the same time both in at the same time
Trailbuster
07-02-2007 07:05:17
 Re: AC Sickle broke in reply to Traditional Farmer, 07-02-2007 02:39:13
Well, nuts.
I guess I've got to pull it apart again and change the timing of the flywheels. Since this is the case, how much does this sickle mower shake side to side when in operation?
Carp
07-02-2007 09:02:18
 Re: AC Sickle broke in reply to Trailbuster, 07-02-2007 07:05:17
Very little. The flywheels are ballanced to compensate for that.
