case ih 445 baler update help needed
havvey
07-01-2007 18:13:54
well its does not seem to be the brake. the needles want to cycle all the time. The problem seems to be in the inner trip mechanisam behined the inboard knotter. the baler recently was working and had a lond road trip. any help
havvey
07-03-2007 04:54:59
 Re: case ih 445 baler update help needed in reply to havvey, 07-01-2007 18:13:54
Thanks all it was the trip and arm it is now fixed.
johns48jdb
07-02-2007 13:48:09
the cam that rides inside of the star shaped wheel at the back is staying up. push it down and see why its hung in the up position. turn the bailer over by hand until you get this problem fixed or you could be asking for more trouble. you need an owners guide to see where to lub all the places on this bailer or somebody who is familiar with one to go over it with you. if its like a 440 there is one behind the left tire that you'll miss. keep an eye on the bearings that the plunger glides on. there is a grease fitting in behind the rols of twine and be sure an always grease the one that you get to from the top that goes to the main block the knotters are mounted to, if its like a 440. keep the shear bolt tight on the flywheel. i always double nutted mine.
435
07-02-2007 07:50:15
The cam is not returning to home after the needles cycle. Use some WD 45 and then shake the trip bar.
