Rhino bushhog gearbox
Melvin Shaw
06-30-2007 05:19:27
I'm looking for a seal for the gearbox on a bush hog and all I've found is a series of numbers. Does anyone have a website of someone I can contact to find a seal? I'm not sure of make, but it's a 6 ft. Numbers I found are 9J10042001xx{30)?? Thanks
Billy NY
06-30-2007 05:45:59
 Re: Rhino bushhog gearbox in reply to Melvin Shaw, 06-30-2007 05:19:27
Speak with Isaac (800) 414-4705 Binkley & Hurst
I have a cut of the gearbox in section and a parts list, not sure if it applies to your 6'-0" Rhino. I get my parts from this place for my SE-6 Rhino. Hopefully you have the serial number tag on the deck, that ought to help, mine was older and they did not seem to have the corresponding parts book, however they used a later one and the configuration and parts were the same, so I lucked out and got the right parts on the first try, which where blade bolts. Gearbox parts catalog cut I have is Gearbox assembly Rev 06-04, SE6 (Apr-04) S/N 29675 - Current Rev. 06-04 parts section - 14 (assume that to be page 14) copyright 2004 alamo group.
I contacted Servis/Rhino and asked to get a parts catalog for my serial number Rhino SE-6 and all I got from them was literature on new ones ! It's a good rotary cutter, even being an older model, performs great.
