Cone-type 3-point broadcast spreader question
CB in central N
06-27-2007 09:02:45
I am looking to get a 3-point broadcast spreader to apply powder fertilizer to my hayfields. I have had soil tests done so I know what chemicals and at what rate to apply them. Question is, how do you set the rate? I know that the spreader has an adjustable "gate" at the bottom for various rates of flow. But the rate of application is also going to depend on how fast the tractor is moving. I am looking for advice as to how to combine the two so that I know how much material is actually getting dumped on the field. Thanks in advance to all who answer.
MLD
06-28-2007 05:49:31
 Re: Cone-type 3-point broadcast spreader question in reply to CB in central NY, 06-27-2007 09:02:45
There should be a chart on the spreader to give you lbs. per acre. I usually set mine alittle less than the chart becuse I'm scared of running out before I get over all the land. Usually the chart is right & I end up going over it twice, one day I'll learn.
Tom in TN
06-27-2007 19:02:51
CB,
This might not match your situation at all, but I rent a large broadcast spreader from my local Co-Op where I buy my fertilizer. The spreader is ground driven and has a well marked gate that is adjusted based on the number of pounds of fertilizer you want to spread per acre. The "cart" as they call it, costs $30.00 to use it. The bulk fertilizer is much less expensive than bagged fertilizer, so I figure it is more than a good trade-off for the rental of the spreader.
Good luck,
Tom in TN
johns48jdb
06-27-2007 15:00:52
you might want to consider having it spread with a truck. those guys should know what to set their rigs at. the cost of materials in bulk and your time spreading it may go a long ways toward paying to have it done. then you might not get to get out and play.
paul
06-27-2007 11:30:26
As Fighting S says..... Was going to suggest that site as well. :)
Spreading is a good guess, you'll have to do it a time or two & learn how to guess better. Different fertilizers will sling differently. Applying 1/2 and going over 2x will really help.
--->Paul
Fighting suburbia in NC
06-27-2007 10:14:14
 Need owner's manual for particular model in reply to CB in central NY, 06-27-2007 09:02:45
In the owner's manual (if you can find one for it) there should be charts to give you a rough estimate of rates being applied per setting. It should look like the charts at the end of link below.
In the past I have set about a half rate and then made sure to overtravel the area twice at differing angles, but that may not work for your situation. There is really no precision to a slinger like there is a drop spreader but then most fertilizer/lime applications will be close enough for guvment work. Dry herbicides may not be the best thing to use a slinger on due to lack of precision.
Best guess on settings and try to drive the same speed is best you can do. Alot of it also depends on the granularity (or lack of) of the material being spread. Good luck and enjoy.
