IHC HM-221 cultivator experts
PurdueAg
06-26-2007 22:32:31
I bought an NOS HM-221 cultivator the other day (i.e. steering gangs). Much of it is still wired together in bundles from the factory. It set around in someone's barn for 60 years. The front gangs and tractor mount were assembled by someone. The problem I have is that some of the parts aren't the same as those pictured in the HM-221 manual (publication date 2-25-49 -- 55A).
In the manual, the lift-pipe bracket attaches to the gang coupling head. The gang coupling head that I have has no place to attach the lift-pipe bracket. Also, the manual has a pressure rod and shield strap bracket attached to the gang (the point of attachment of the pressure rods so the cultivator can be raised). My gangs have no such bracket attached nor holes in the gang for one. There are a couple of pieces that came with my cultivator (but not shown in the parts list in the manual) that look like they might be for attachment of the pressure rods, but where in sam hairy do I attach the lift-pipe bracket? Also, the shifting bar is in one piece rather than 2 as in my manual. Were there different versions of the HM-221, and perhaps I have the wrong manual? Or perhaps the front fram assembly is from a different, but similar cultivator (229? 226?)? All the other parts seem to jive with the manual. Any ideas?
Also, the paint on the gangs, shanks, gang clamp, and gang coupling heads is blue. The paint on the main frame angles, rear rock shaft, lift handles, lift pipe, and shields is red. Is this typical? Hugh Mackay? What is the typical color scheme of the 221?
Thanks for any and all help.
With kind regards,
Tony
Allan In NE
06-27-2007 11:16:25
 Re: IHC HM-221 cultivator experts in reply to PurdueAg, 06-26-2007 22:32:31
There were a couple of variations on that cultivator. One mounted to the rear axle and the other up front on the side of the tractor.
Yes, the colors are correct. The only black came on the shanks of the spud discs.
Allan
georgeky
06-27-2007 11:24:01
 Re: IHC HM-221 cultivator experts in reply to Allan In NE, 06-27-2007 11:16:25
Some were black and some not. Mine are all blue, no black ever on them.
georgeky
06-26-2007 22:49:39
The only question I can answer is about the color. Yes they were blue and red. I have a HM 438 and the frame is red and everything else is blue. This is original paint, or what is left of it. When I bought the cultivator 20 years ago it had all the original paint still on it. Not wanting anything to come of the paint, I put them in a tobacco barn. Came back in early September and don't you know, they were covered in bird crap an inch deep. As you might guess that was the end of my good original paint. There is a little of it left, but very little.
