John Deere FBB Grain drill question
L. Gerig
06-26-2007 15:52:17
Does anyone know where to set the drill to be able to plant approximately 25# of Sudan grass seed per acre?
Dave Anderson
06-26-2007 16:50:16
 Re: John Deere FBB Grain drill question in reply to L. Gerig, 06-26-2007 15:52:17
I was speaking of the main seedbox, to clarify.
Dave Anderson
06-26-2007 16:49:10
The lowest Amount of sudax seed that I could get my JD FB was in the neighborhood of 80lbs/a at a setting that barely exposed the seed gear. Be sure that your seed doors are in the right position-closed as tight as they go. The FB, FBA, and FBB used the same seed drop mechanism, so if you can find one of these drills in the bushes somewhere, the tin chart in any one would serve your purposes well.
Forgot password (again!)
06-26-2007 16:40:54
Just wondering, are you using a grass seed attachment or some other way?
